em 16-04-2023 07:38 PM
Eu quero comprar um cartão SIM.
É possível encomendar e comprar um cartão SIM com um determinado conjunto de números (entre disponíveis, não utilizados)? Por exemplo,
+351-código da operadora-333-33-33 e assim por diante?
em 12-09-2023 10:43 PM
em 13-09-2023 01:08 AM
Hello, @Michaela
Thank you for your message.
It is possible for a Vodafone customer to change their telephone number to a preferential number, however with the numbering you indicate, there are currently no telephone numbers available.
Thank you
em 17-04-2023 11:43 AM
Before buying a SIM card, can I find out if the numbers I'm interested in are free? How can I find out if rooms are available?
em 17-04-2023 12:59 PM
It is only possible to check if the number you want is available after you have a SIM card.
You can get a free SIM card here. After having it in your possession, we can check in our system the availability of the number of your choice.
For this, you will need to send us a private message with your current number and the number you want to switch to.
To send a private message, click on one of the moderators (these are the users identified with "name_Vodafone") and choose "Send a private message".
We hope we clarified this question.
Thank you,
Susan_Vodafone
em 17-04-2023 01:56 PM
I understood you correctly: I buy any or order a vodafone SIM card. then I write you the number of the purchased card and I write you a few numbers to which I want to change the already purchased SIM. Then you check those numbers. If they are available - change my number. It's like that?
map.
em 17-04-2023 02:31 PM
Correct, once you have your SIM card you can contact us by private message telling us the number you already have and the number you want to join.
Thank you,
Carol_Vodafone
em 17-04-2023 02:35 PM
Fine. I'll buy a sim card and get back to you here.
Tell me, do you have packages that do not provide for constant monthly replenishment?
em 17-04-2023 03:17 PM
Vodafone has non-buying tariffs, such as Vodafone Easy and Vodafone Directo, you can check all the conditions of these tariffs here.
Thank you,
Carol_Vodafone
em 18-04-2023 11:54 AM
Does the free SIM card come with mandatory monthly payments?
em 18-04-2023 02:08 PM
